Mp4-21 Breaks Cover At Barcelona
#3
Posted 23 January 2006 - 10:05 AM
ben_3001, on Jan 23 2006, 03:28 PM, said:
plus return of tyre changes
Kimi will have his hands full
not to mention his useful(to renault )teammate
narain fan, on Dec 30 2006, 12:32 AM, said:
and if you dont want to read my posts,no on is forcing you
#4
Posted 23 January 2006 - 10:19 AM
#5
Posted 23 January 2006 - 10:34 AM
Looks sexy on this angle I must admit!!
#6
Posted 23 January 2006 - 10:49 AM
"I am really pleased to have been at the wheel of MP4-21 today. The car feels good initially, but it is of course too early to really understand it's potential and we need to put a lot more laps on it. We have around 20 days of on track running before the cars leave for Bahrain on Friday 3rd March. As today is the initial shakedown, our focus will be to familiarise ourselves with the MP4-21 and the Mercedes-Benz FO 108S V8 engine, and to run the various systems checks that are required with a new car."
Martin Whitmarsh, CEO Formula One, Team McLaren Mercedes
"Everyone at Team McLaren Mercedes is looking forward to the challenges ahead this season, and we took a major step in our preparations for 2006 today by starting to test the MP4-21 at Barcelona. The anticipation within the team as to how competitive the new car will be is great, particularly given the pace of our 2005 racer and the level of work that has been put into the MP4-21 project. However these are early days, we have a comprehensive programme to complete with the car over the next few weeks. This will mean hard and dedicated work from the whole team supported by our Technology Partners and Official Suppliers, including an aggressive schedule of upgrades to come on line before Bahrain."
The revised engine regulations for 2006, with the change from V10 to V8, has dominated the overall design process. Research into a direction for the MP4-21 began in August 2004, when Team McLaren Mercedes started to consider the new V8, 2.4 litre power plant, which as in 2005 has to last for two Grands Prix weekend. Designed and built from scratch, the Mercedes-Benz FO 108S V8, which ran for the first time at Silverstone on 13th September 2005 following its dyno debut on 15th June of the same year, also has to conform to the below restrictions:
* V-angle of the cylinders set a 90 degrees
* Use of a maximum of two inlet and exhaust valves each, previously restrictions have only covered the number of cylinders and a limit of five valves
* Minimum engine weight of 95 kilograms
* Maximum cylinder bore of 98 millimetres
* The position of the engine's centre of gravity
* Precisely defined alloys for the manufacturing of engine components
Norbert Haug, Vice President, Mercedes-Benz Motorsport "The challenge with a brand new Formula One car is the same every year, but nevertheless there were even more intensive tasks to be dealt with this year than ever before. The regulations require new V8 engines with a 2.4-litre capacity, and in addition to this the need to compensate for the restriction of the aerodynamics, this took a lot of time and effort. The power reduction by more than 150 bhp put additional strain on the aerodynamic concept. The aim was to further reduce drag and maintain or even increase downforce – which with the given limitations reminded the technicians that it is possible to achieve the impossible. As a result of this complex task it was important to invest sufficient time before the final definitions were made. We are very satisfied that the new MP4-21 has had a successful debut today. Its basic data promises that we have got a good basis. Our new engine covered about 6500 kilometres on track and more than double this amount on the dynos in Brixworth and Stuttgart. Now it is our task to prepare the new car for Bahrain in six more tests with more than 20 testing days when most of the time two MP4-21s will be run following Barcelona. The aim is to continue on last year's level of performance."
In October of 2004, the design team began its research into revised engine systems concepts, with the new regulations providing the opportunity to develop areas such as the cooling system, air and oil consumption and fuel supply.
Martin Whitmarsh
"The development of the Mercedes-Benz V8 engine, and its ancillary areas, has seen McLaren Racing provide a strong supporting role to Mercedes-Benz High Performance Engines, further integrating the facilities in Woking, Brixworth and Stuttgart."
Aerodynamics also received early attention, with the development programme starting as the 2005 season was getting underway in April of that year and the aero specification set in late October / early November. A key area of focus was the opportunity to exploit the smaller power unit by repackaging the rear of the car. In addition, the regulation change that stipulates the forward deflectors ahead of the reference plane must be raised by 50mm proved to be significant to the aerodynamics of MP4-21 and required innovative solutions from the Team McLaren Mercedes design team.
April 2005 also saw initial transmission and drive train work begin and the following month, the first spec of MP4-21 was issued by the design team. By September, production had begun, with chassis manufacturing starting one month later.
Other key regulation changes include the increase in crash test loads to the rear structure by 50 per cent, leading to the development of complex composite structures to absorb the required energy. Late December saw the MP4-21 chassis complete its first FIA crash test.
On the sporting side, there is a new qualifying format and the return to tyre changes in pit stops. The latter has been a focus of the extensive winter testing schedule throughout December and January to date, with the team working alongside Michelin to develop the new compounds and constructions for 2006. By the end of the final test in December 2005, Team McLaren Mercedes had covered over 6,000kms with the Mercedes-Benz V8 engine.
Jonathan Neale, Managing Director of McLaren Racing
"Visually MP4-21 will look very similar to MP4-20. In addition to the tighter packaging to the rear of the car, people will notice differences to the nose area, which has been lowered, and the aero body work, such as the barge boards and deflectors. The reduction in required cooling for the V8 engine has allowed us to in turn reduce the size of air intakes, this includes apertures in the main chassis, which is beneficial to the overall aerodynamic package. There are a significant number of changes in the cars structure, geometry and aerodynamics as a consequence of 16 months of R&D innovation. At McLaren Racing, we have a strong team of 135 engineers, and all have made a vital contribution. Now the new car has been released, our primary short term focus will switch to durability testing, proving the software, the systems and the 11,500 car components, 90% of which have changed from MP4-20. In addition we have a series of engine and chassis performance packages to bring to the car for the initial races. There is a lot of work to be done."
Source McLaren
#7
Posted 23 January 2006 - 10:58 AM
Listening to: Cracker - Kerosene Hat
Dig that jive, Jack. Put it in your pocket, and don't look back.
#8
Posted 23 January 2006 - 11:40 AM
Nobody bitched when McLaren and Williams dominated F1...
www.f1weekly.com
AutoRacer5 vs. Ecapdeville on Fight Night Round 3:
6-1
AutoRacer5 vs. Ecapdeville on Forza Motorsport:
4-4
UrKo, on Sep 10 2006, 4:06 PM, said:
My blog: http://openwheelrants.vox.com/
#9
Posted 23 January 2006 - 11:51 AM
AutoRacer5, on Jan 23 2006, 05:10 PM, said:
Edited by narain fan, 23 January 2006 - 11:53 AM.
#11
Posted 23 January 2006 - 01:20 PM
- Kimi Raikkonen on his reasons for leaving Formula 1 for the WRC
#14
Posted 23 January 2006 - 03:24 PM
#15
Posted 23 January 2006 - 05:25 PM
#16
Posted 23 January 2006 - 05:28 PM
#18
Posted 23 January 2006 - 06:18 PM
Jenson_Rules!!!, on Jan 23 2006, 11:28 AM, said:
todays testing times were not for "judging" purposes. The sole purpose was for system checks. As with any new car being rolled out, the team will not push the car to its limit right away. Having said that, the front reminds me of the failed Mp4-18 model.
Edited by juanpablo, 23 January 2006 - 06:23 PM.
#19
Posted 23 January 2006 - 06:43 PM
juanpablo, on Jan 23 2006, 07:18 PM, said:
They had 2 red-flags on it's first outing and only were able to do 18 laps before the motor called quits. Can't imagine what it gonna give when they do start to push
#20
Posted 23 January 2006 - 06:49 PM
ben_3001, on Jan 23 2006, 12:43 PM, said:
ur right there. But I cant remember the last time Mclaren had a shakedown of their new car and did NOT cause a red flag. It has been happening every time since the late nineties!
What really matters is the problems they might have after the initial teething troubles. That is when we actually get to the "real" problems.
Also..a problem filled day of 18 laps is no measure of how "quick" the car might be
Edited by juanpablo, 23 January 2006 - 06:51 PM.
#22
Posted 24 January 2006 - 02:16 AM
monza gorilla, on Jan 23 2006, 02:58 AM, said:
Yes it does have that anteater look to it
Livestrong
Forza Ferrari!!!!!
Forza Italiano!!!!!!!!
"I reject your reality and substitute my own"------Adam--Mythbusters
#23
Posted 24 January 2006 - 02:47 AM
2005 drivers champion: Fernando Alonso. Good Job Fernando, awesome year
#24
Posted 24 January 2006 - 03:50 AM
#25
Posted 24 January 2006 - 05:38 AM
juanpablo, on Jan 23 2006, 06:18 PM, said:
for some reason I dont find that compairing a car the mp-18 very insuring considering it never even raced
maybe its me but the front wing seams to be the biggest i have ever seen.
Jacky Ickx at La Source during practice for the 1970 Grand Prix of Belgium
The Masters have returned.
"People were being killed left, right and center back then," [Phil Hill] says. "I became hyper-sensitive to the danger, and wasn't sure that I wasn't going to kill myself. As a result, racing brought out the worst in me. Without it, I don't know what kind of person I might have become. But I'm not sure I liked the person I did become, because I was selfish, irritable and defensive."
#26
Posted 24 January 2006 - 08:17 AM
"You just don't mess with Jacques Villeneuve" - Murray Walker, 1997 Hungarian GP.
"When Jacques was with us, he was a very aggressive driver, fiercely competitive, mentally hard as nails. Very quick with it, very gifted. A bright fellow, undoubtedly, very intelligent. He was an absolutely born racing driver - look at the way he'd bang wheels with Michael, pass people on the outside, that kind of thing" -Sir Frank Williams on Jacques Villeneuve
"This year, with BMW, JV's going very well, and I'm pleased for him. Whether or not he'll get a drive next year I don't know, but I hope he does, he's an unusual, and very strong addition to the F1 community. A character." - Sir Frank Williams again on Jacques Villeneuve
The Nojvnof1 2006 driver lineup - Jacques Villeneuve, Nico Rosberg, Christian Klein, Scott Speed.
#29
Posted 24 January 2006 - 03:20 PM
Wez, on Jan 24 2006, 08:45 PM, said:
it is the "initials" of the website from which i pasted the pics
Edited by narain fan, 24 January 2006 - 03:21 PM.
