Jenson_Rules!!!, on Jan 27 2006, 08:04 PM, said:
. No offence of course, but FW looks like timmy from south park in that pick.
how can you possibly come with such comments
Most people involved in the intimacies of Formula One place great value in the principle of stability in the technical regulations - from the rule makers themselves to their intellectual adversaries, the design engineers. Routine changes to the rules that govern the sport cost money and, from an engineer’s perspective, changes normally imply more restriction and less freedom to innovate, to exploit new materials or to pursue a promising development break. Generally, then, rule changes are the stuff of nightmares to most ambitious Formula One designers.
However, at a more forensic level of analysis, change to the technical regulations could actually be considered the engineer’s friend. With convergence of technological infrastructure between competing Formula One teams and the reduction in latitude for genuine innovation imposed by tighter regulations, the engineering initiative is now largely process-driven. Teams are all working at the very margins of improvement, albeit tenths of a percent in downforce gain or nominal improvements in mass transfer or CofG. Shifting the battle to one that is process-driven means that the team that gets its small increments of improvement to its race car the quickest, and in the most reliable way, will win.
So the 2006 regulations, which have defined the development of the FW28, represent in many ways one of the occasional opportunities that come knocking on an engineering department’s door, presenting a step change in a number of key design areas, which in turn promises a rich, rewarding and unpredictable season in prospect.
Clearly the biggest transition is the shift away from 3.0l v10 motive power in favour of 2.4l v8, and in Williams’ case, the new partnership with Cosworth. With the associated power losses all teams will encounter, everyone is facing a demand for higher aerodynamic efficiency to help compensate. In the case of the FW28, this became a fundamental design parameter for the car and is reflected in many ways across the aerodynamic strategy of the car, visible particularly in the design of the rear wing with its decambered tips. The target here was to maintain downforce while shedding drag at the wing tips. Additionally, a tall sidepod concept was adopted which allowed an even larger undercut and therefore smooth and efficient air flow to the rear of the car.
While designers have been forced to grapple with recouping power losses through aerodynamic efficiencies, the FIA dealt another blow to designers by imposing a new restriction on bodywork to the front of the car, removing the bottom parts of any forward barge boards and, in the process, dramatically altering flow dynamics around the front of the car. The response in the Williams design office has been to pursue a zero keel option to the management of the front wishbones. This area of design has been one of fundamental contention and revision across the Formula One paddock, but the zero keel solution now clearly provides the most efficient aerodynamic solution. In addition, the team has progressed the cascaded front wing, trialled successfully in the last two Grands Prix of 2005.
The revised three part qualifying format, essentially with the first two elements on low fuel and the final session based on race fuel, has had major implications for the approach to 2006 race strategy and in turn, with the design and all-important capacity of the fuel cell. Equally, the regulators decision – after a season of outlawing the practice – to re-enshrine tyre changes has a clear line of influence over the design of the elements of the car that respond to the changing parameters of tyre wear, fundamentally in relation to the mechanical set-up of suspension elements and weight distribution.
If the external factors were not sufficient to keep the design office at Williams busy with the incarnation of the FW28, the technically motivated switch to Bridgestone tyres (which the team last raced in 2000) has demanded a complete revision of weight distribution across the car and a re-formatting of suspension geometry in order to harmonise the dynamic characteristics of the FW28 with the qualities of the Bridgestone tyre. Technical Director, Sam Michael, commented, “The FW28 has been a large departure from previous Williams’ designs due in part to new aerodynamic efficiency targets, but also the mechanical challenges of changing to Bridgestone tyres and Cosworth’s v8 engine. It has been a really interesting car to design and I believe that will continue to be the case during its development in 2006.”
The shift to Cosworth has been another fundamental element in the genesis of the FW28. The development of the CA V8 has been characterised by an open and culturally convergent philosophy between the two organisations, which has been nothing short of positive and productive. As Alex Hitzinger, the architect of the CA V8 reflected, “We both have something to prove this year and this is when we will be at our best.”
Alongside the new V8 powerplant in the drivetrain design strategy has been the progression of Williams seamless shift technology which is anticipated to come on stream in the early part of the 2006 season. This seven-speed continuous torque gearbox owes much of its development progression to the joint validation work conducted on Cosworth’s dynos in Northampton, indicative of the depth and strength of the technical partnership. Seamless transmission can be worth up to 0.4 seconds over the course of an average racing lap.
The team has progressed the development of the FW28, together with the input from its technical partners, with an added degree of relish over the winter. Although not openly admitted, the extra challenge presented by the rule changes has galvanised the engineers into a mood of positive engagement. This is, in fact, where Williams should be at its best. For Sam Michael the objective is clear, “The FW28 has a lot resting on its shoulders as it must re-establish Williams at the sharp end. There are many good teams in Formula One now and how to beat them is simple – design a faster car.”
Fundamental rule changes and new technical partnerships with Bridgestone & Cosworth all equate to a heady c#cktail for the Williams design team to tackle. However, the FW28 is a first design for Sam Michael’s new combination of Chief Aerodynamicist, Loic Bigois and Chief Designer, Jörg Zander. For the first time too, the design team has had the benefit of two onsite wind tunnels dedicated to the new car from the outset and while nothing is meaningful until one Sunday in early March, certainly the circumstances of the FW28’s genesis could not be better for Williams, nor indeed could the response from its creators.
THINGS YOU DIDN’T KNOW ABOUT THE FW28
The FW28 is the first car to fully benefit from the recently improved WilliamsF1 aerodynamic facilities, including two full time, on site wind tunnels. The car uses a zero keel chassis concept, developed to improve the aerodynamic efficiency of the car. The change in FIA aerodynamic regulations at the front of the car was a significant input to the development of the FW28 chassis.
With a reduction in power (as the engine has dropped from a 3.0l v10 to a 2.4l v8), a higher aerodynamic efficiency is required. This is the main reason for the FW28 rear wing design and the disappearance of less efficient components such as rear light wings and secondary roll hoop wings.
Cars are rebuilt between every Grand Prix. This involves full strip down and servicing of the fuel system, hydraulics, steering, gearbox and electrical systems. In addition to this, all the composite and metallic parts are inspected and crack checked for damage.
It takes two days to build an FW28 from a bare chassis to a fully rolling car.
williamsf1
Edited by narain fan, 27 January 2006 - 02:46 PM.
