Chassis code TF104
Material Carbon fibre
Transmission Toyota seven-speed semi-automatic titanium gearbox
Front suspension Push rod with torsion bar
Rear suspension Push rod with torsion bar
Dampers Sachs/Toyota
Wheels BBS Magnesium
Front wheel diameter 13in x 13in
Rear wheel diameter 12.5in x 13.7in
Tyres Michelin Pilot
Brakes Brembo
Steering Toyota
Electronics Magneti Marelli
Battery Panasonic
Dimensions
Wheelbase 3090mm
Total Length 4627mm
Front Track 1425mm
Rear Track 1411mm
Weight 600kg including driver
RVX-04 Technical Specifications
Engine Code RVX-04
Number of cylinders 10
Angle 90° V-angle / 3000 cc
Spark Plugs Denso
Fuel and Lubricants Esso
Maximum horsepower Around 900 bhp
Maximum revolutions Around 19,000 rpm
Toyota TF104 Tech Specs
Started by
admin
, Jan 17 2004 03:25 PM
No replies to this topic
