The F2004, technical specification
Model
F2004
Engine
Type 053, V10, cylinder block in cast aluminium
Total displacement
2,997 cm3
Timing gear
Pneumatic distribution, 40 valves
Fuel feed
Magneti Marelli digital electronic injection
Ignition
Magneti Marelli static electronic ignition
Transmission
Ferrari longitudinal gearbox. Limited-slip differential. Semiautomatic sequential electronically controlled gearbox, 7 gears + riverse
Chassis
Carbon-fibre and honeycomb composite structure
Suspension
Independent suspension, push-rod activated torsion springs front and rear
Brakes
Ventilated carbon-fibre disc brakes
Length
4545 mm
Width
1796 mm
Height
959 mm
Wheelbase
3050 mm
Front track
1470 mm
Rear track
1405 mm
Weight with water, lubricant and driver
605 kg
Wheels (front and rear)
13”
Ferrari F2004 Tech Specs
Started by
admin
, Jan 26 2004 12:56 PM
No replies to this topic
