Ferrari F2007
81 replies to this topic
#1 c21
c21
  • 1,327 posts
Posted 14 January 2007 - 03:21 PM
Well, its time, and there are no pictures as of yet but these details are now released.....
The F2007 is the fifty third single-seater built by the Scuderia Ferrari specifically to compete in the Formula 1 World Championship. The Launch of the F2007 started at 4pm at Maranello, the home base of the Italian team.
The F2007 is the fifty third single-seater built by Ferrari specifically to compete in the Formula 1 World Championship.
The project, known internally as the 658, represents the Scuderia's interpretation of the technical regulations that apply for 2007, with changes principally concerning safety, through the introduction of more stringent front and rear crash tests and the addition of a composite material structure to provide lateral protection to the sides of the driver. These modifications have led to a significant increase in the weight of the car, in the region of just under ten kilogrammes.
The F2007 chassis has been significantly modified when compared to the 248 F1. The design was revised to accommodate a new front suspension that represents a major conceptual innovation, mainly in terms of aerodynamics. The shape of the side-pods and their openings are also revised, based on modifications to the cooling system, which also implies exits for the radiators on the upper part of the bodywork, while the engine air intake is also substantially different. The car has a longer wheelbase than its predecessor. The rear of the car is much narrower, taking advantage of the more sculpted shape of the gearbox housing, which again this year is made from carbon fibre. The gearbox itself, which is still mounted longitudinally, is fitted with an innovative quick-shift system (seven plus reverse). The rear suspension is similar to that on the 248 F1, but a significant development programme is planned in this area, in order to get the most out of the system, based on making progress in understanding the behaviour of the 2007 tyres. The front and rear aerodynamic configuration is also expected to change considerably before the start of the World Championship. The position of the rear view mirrors seen on the 2006 car remains unchanged and the same goes for the exhaust system.
In accordance with the regulations that come into force this year, the basic structure of the engine remains the same as the one homologated at the end of last season. Therefore, the 056 engine continues as a load bearing member and is again mounted longitudinally. Based on what is permitted in the regulations, the following modifications have been carried out to the engine signed off with the FIA in October 2006:
· the combustion chamber, the valves, the inlet and exhaust chambers, all aimed at optimising the torque curve, given the engine rev limit of 19,000 rpm;
· the piston, the piston pin and the piston cooling jets to aim for the best possible reliability when running at the limit of 19,000 rpm;
· the fluid systems (water and oil) and components to facilitate the integration of the 056 into the new car.
As usual, during the design and development phase of the complete car, the technical partners played an important role. A significant part was played by Shell in terms of fuel and lubricants, by the Fiat Research Centre in the use of simulation systems and by Brembo in developing the braking system. As is now traditional, a great deal
of attention was paid to the performance and optimisation of the materials used, to the design stage and to quality control, striving to maximise the performance level and to ensure the highest possible standard of safety.
Chassis
* Carbon-fibre and honeycomb composite structure
* Ferrari longitudinal gearbox
* Limited-slip differential
* Semiautomatic sequential electronically controlled gearbox - quick shift
Number of gears: 7 +Reverse
* Ventilated carbon-fibre disc brakes
* Independent suspension, push-rod activated, torsion springs front and rear
Length: 4545 mm
Width: 1796 mm
Height: 959 mm
Wheelbase: 3135 mm
Front track: 1470 mm
Rear track: 1405 mm
Weight with water, lubricant and driver: 600 kg
Wheels (front and rear): 13"
Engine
Type: 056
Number of cylinders: 8
Cylinder block in cast aluminium: V 90°
Number of valves: 32
Pneumatic distribution Total displacement: 2398 cm3
Piston bore: 98 mm
Weight: > 95 kg
Magneti Marelli digital electronic injection
Magneti Marelli static electronic ignition
Fuel: Shell V-Power ULG 62
Lubricant: Shell SL-0977
Edited by c21, 14 January 2007 - 03:21 PM.
Quiet one:
"I have officially addded you to my enemies list, along with Schumacher, Todt, Ecclestone, Bill Gates and that annoying biker frog."
#2 theLinK
theLinK
    Test Driver
  • New Members
  • 1 posts
Posted 14 January 2007 - 03:48 PM
Here it is, Hopefully there will be more to come.
[attachment=875:1168788753.jpg]
[attachment=876:851168789361.jpg]
Edited by theLinK, 14 January 2007 - 03:53 PM.
#3 ykickamoocow
ykickamoocow
  • 6,717 posts
Posted 14 January 2007 - 04:10 PM
Ive found some more
Its certainly a interesting livery. It looks like a McDonalds sign.
DC: "I am not motivated by recognition, I just do things I like doing - racing, shagging, eating and drinking."
Dave Hughes: Taking drugs is like taking a ride to New Zealand on a concorde. The trip is good but once you land you end up in a bad place."
Officially the most bias member of the totalf1 forum
#4 DMB
DMB
    Test Driver
  • Validating
  • Pip
  • 39 posts
Posted 14 January 2007 - 04:13 PM
Wow, this new Ferrari looks beautiful. The front nose cone reminds me a little of the RB2's on your third picture ykick.
And those yellow contraptions in the side pods, are they permanent or placed there just for the presentation?
#5 c21
c21
  • 1,327 posts
View Postykickamoocow, on Jan 14 2007, 05:10 PM, said:
Ive found some more
They arent very revealing, they dont tell us very much.
I guess we have to wait until it hits the track
Quiet one:
#6 ykickamoocow
ykickamoocow
  • 6,717 posts
Posted 14 January 2007 - 04:20 PM
That is not a very good sign for Ferrari as the RB2 handled like a lubricated pig walking on a polished wood floor.
I have also found another photo
Edited by ykickamoocow, 14 January 2007 - 04:24 PM.
#7 c21
c21
  • 1,327 posts
Posted 14 January 2007 - 04:24 PM
Those are just blanking panels so we cant see inside.
Either there is something new in there, or most likely the car is not complete with the ducting and radiators missing.
Quiet one:
#8 Player(1)
Player(1)
    Champion Del Mundo!
  • 1,512 posts
Posted 14 January 2007 - 04:25 PM
:roll:
Posted ImagePosted Image
View Postgoferrarigo, on Apr 17 2007, 11:15 PM, said:
Yeah Kimi should be winning this one,
View PostAutumnpuma, on Apr 19 2007, 03:32 AM, said:
Yeah, that sounds right. Mikey was the well-hung gent to Steve's innocent school-girl.
#9 Ctrl300
Ctrl300
    Toppbanana
  • 1,786 posts
Posted 14 January 2007 - 04:43 PM
Bitch nigga mobile if I ever saw one.
The MP4-22 is going to eat it for breakfast. All the broke Indian bitches can eat a dic..
Compared to the R-26 it looks like a black boys wet dream, in other words a box car.
Evolution, ok, revolution, no way.
Bring on 2007, McLaren 1-2.
Essential reading "While Europe Slept" by Bruce Bawer
#10 Jean Todt
Jean Todt
  • 7,919 posts
Posted 14 January 2007 - 04:45 PM
They are just covers, may be either to hide something or protect it from dust or other elements.
#11 Jean Todt
Jean Todt
  • 7,919 posts
Posted 14 January 2007 - 04:46 PM
:roll:
#12 Ctrl300
Ctrl300
    Toppbanana
  • 1,786 posts
Posted 14 January 2007 - 04:53 PM
Nigga, please
#13 Player(1)
Player(1)
    Champion Del Mundo!
  • 1,512 posts
Posted 14 January 2007 - 04:58 PM
Just noticed the Ferrari and Renault didnt have the wing planes on the side of their nose cones like last year but the Toyota does which means 1 of 2 things.
1. They have become obsolete for some reason and Toyota is the last to know...like with their sidepods.
2. They are not finished car's.
I'm suspecting its number 1 seeing as Renault where doing an aero test so i'd assume the aero would need to be complete for them to test it. (nose winglets would effect the aeroflow to the rear so would make any aero there give false readings to its final effect)
#14 c21
c21
  • 1,327 posts
Posted 14 January 2007 - 05:01 PM
Not necessarily, we only had a couple of pics of the Renault. for a aero test you could have many configurations to try out. there's no reason there is not a nose with winglets in the truck to try later.
Quiet one:
#15 Player(1)
Player(1)
    Champion Del Mundo!
  • 1,512 posts
Posted 14 January 2007 - 05:08 PM
I thought of that but remembered Monza(?) the fastest track top speed wise they still used winglets on the nose just cut down alot.
Edited by Player(1), 14 January 2007 - 05:11 PM.
#16 c21
c21
  • 1,327 posts
Posted 14 January 2007 - 05:12 PM
View PostPlayer(1), on Jan 14 2007, 06:08 PM, said:
I thought of that but remembered Imola the fastest track top speed wise they still used winglets on the nose just cut down alot.
It also depends on the overall package, just because the wings work on some cars, it does not mean they work on them all.
These wings are there to direct airflow, maybe the Renault does not need them and the Toyota/crate does.
Quiet one:
#17 AutoRacer5
AutoRacer5
    Making Blumpkin Pie
  • 5,210 posts
  • Interests:women, racing, alcohol.
Posted 14 January 2007 - 05:42 PM
That's fiyah.
Nobody bitched when McLaren and Williams dominated F1...
www.f1weekly.com
AutoRacer5 vs. Ecapdeville on Fight Night Round 3:
6-1
AutoRacer5 vs. Ecapdeville on Forza Motorsport:
4-4
View PostUrKo, on Sep 10 2006, 4:06 PM, said:
....parabolica is in S2.....
My blog: http://openwheelrants.vox.com/
#18 Autumnpuma
    Back in black
  • 8,830 posts
Posted 14 January 2007 - 05:49 PM
I like this line:
"The design was revised to accommodate a new front suspension that represents a major conceptual innovation, mainly in terms of aerodynamics."
Interesting. I thought this wasn't allowed....ah well, for Ferrari, anything goes.
Don't rest in peace, Bruce. Raise Hell.
______
Give me a roof over my head, some food to eat and a fast car. That's all I need.
That's all I'll ever need.
----Robert Kubica
"Gilles was the last great driver. The rest of us are just a bunch of good professionals."
----Alain Prost
The only true sports are motor racing and mountain climbing; everything else is just a game.
TF1 Blogs: be afraid, be very, very afraid..........
#19 F1 FANatic
F1 FANatic
    Back Seat Driver
  • 1,425 posts
Posted 14 January 2007 - 07:10 PM
man, all the pictures are at such bad angles. and no Puma, innovation is only allowed for one year ala Mad Max proclamation
too bad teams can have movable wings, think of what they could do if they had servos in the wings to move the wings like flaps of an airplane to help turn the car
and is the official name now actually the f2007? i found the new naming system cooler. Ferrari 248 F1 just sounded better then F2006
Edited by F1 FANatic, 14 January 2007 - 07:13 PM.
Jacky Ickx at La Source during practice for the 1970 Grand Prix of Belgium
The Masters have returned.
"People were being killed left, right and center back then," [Phil Hill] says. "I became hyper-sensitive to the danger, and wasn't sure that I wasn't going to kill myself. As a result, racing brought out the worst in me. Without it, I don't know what kind of person I might have become. But I'm not sure I liked the person I did become, because I was selfish, irritable and defensive."
#20 c21
c21
  • 1,327 posts
Posted 14 January 2007 - 07:14 PM
Maybe the innovation is at the rear as there are no photos of that
Quiet one:
#21 aussief1
aussief1
  • 3,909 posts
Posted 14 January 2007 - 09:46 PM
I agree with that. Ferrari issuing no photo's of the sides & rear of the car certainly lead you to believe that Ferrari has something to hide in that area and they want whatever they have developed to remain a secret for as long as possible.
Do any of you guys think that red is more of the old scarlet Ferrari red and not the Marlboro red as in recent years?? It might be the lighting, not sure.
Edited by aussief1, 14 January 2007 - 09:49 PM.
"Giancarlo, you are still two seconds a lap slower than Fernando, this cannot be possible you have the same fuel load, I know you have some understeer but you cannot be two seconds slower, COME ON"!!!! - Alan Permane, Fisichella�s race engineer, 2006 Australian Grand Prix
"We're lucky we don't build aeroplanes" - Mark Webber on Red Bulls reliability issues at the Australian Grand Prix 2008.
Nathan is: .............. ??
#22 james
james
  • 287 posts
Posted 15 January 2007 - 02:53 AM
Heres some high res pics
http://www.seriouswh...rrari-F2007.htm
" I never think I can hurt myself, not seriously. If you believe it can happen to you, how can you do this job? If your never over eight-tenths, or whatever, because your thinking about a shunt, your not going as quick as you can. And if your not doing that, your not a racing driver. Some guys in Formula 1... well, to me, they're not racing drivers. They drive racing cars, that's all. They're doing half a job. And in that case, I wonder why they do it at all..."
"To give anything less than your best is to sacrifice the Gift."
#23 F1 FANatic
F1 FANatic
    Back Seat Driver
  • 1,425 posts
Posted 15 January 2007 - 03:53 AM
ahh, now you can see some detail
the wing/shield things on the side pods looks interesting, not the traditional shape, more square. the end plates of the front wing also went through some changes
and if you look, the car doesn't have any of the electronic fixtures on it, no antennas or such which makes me think the reason the yellow things are in there because there isn't anything in there yet
looking at these hi-res pics shows just how beautiful the car is
Edited by F1 FANatic, 15 January 2007 - 04:06 AM.
#24 goferrarigo
goferrarigo
  • 6,864 posts
Posted 15 January 2007 - 07:06 AM
the car looks nice but i hope the yellow things are just covers. otherwise it looks beutiful
Never argue with an idiot, they bring you down to their level and then beat you with experience - Dilbert
If your lips are extended beyond your nose then you are about to do something rude.  - Scott Adams
#25 Wez
Wez
    World Champion
  • 4,245 posts
  • Interests:Motor Sport, Football
Posted 15 January 2007 - 09:53 AM
I hope for Ferrari fans sakes the yellow covers blocking the engine air intake aren't a feature otherwise Kimi le Car breaker wont last 5 laps in practice!  :P
#26 c21
c21
  • 1,327 posts
Posted 15 January 2007 - 10:06 AM
I can see at least one antenna.
And dont panic guys the  yellow thing are covers I GUARANTEE IT!
Quiet one:
#27 BradSpeedMan
BradSpeedMan
  • 7,300 posts
Posted 15 January 2007 - 10:15 AM
note.
“We keep on working, we do our thing,” Vettel shouts over the team radio, “We are who we are!”
"Vettel is a champion. That’s not referring to his achievements, but rather to his approach to everything he does. He wins. All the time. His preparation is meticulous, his attention to detail reminiscent of Michael Schumacher at his peak, and his performance on the track is almost always flawless. Vettel is capable only of domination. He knows no other way... Vettel is not in Formula One to be liked. He is there to win. And in the words of Ayrton Senna, perhaps the greatest of all Formula One drivers, “Nice men don’t win.”"
Chris Cameron-Dow
#28 Wez
Wez
    World Champion
  • 4,245 posts
Posted 15 January 2007 - 12:06 PM
View PostBradSpeedMan, on Jan 15 2007, 12:15 PM, said:
note.
Brad, that note is only valid if Ferrari use those yellow plugs for the entire race season!
#29 ykickamoocow
ykickamoocow
  • 6,717 posts
Posted 15 January 2007 - 12:33 PM
Alright i have offical photo's from Ferrari which has better angles of the new car
Plus i have photo's from its shakedown test being conducted as we speak
#30 ykickamoocow
ykickamoocow
  • 6,717 posts
Posted 15 January 2007 - 12:38 PM
First laps in the F2007
At foggy Fiorano this morning, Felipe Massa turned his first laps in Ferrari’s 2007 challenger, the F2007.
The car, which currently features 2006 front and rear wings, is to undergo extensive testing over the next two months and according to Aldo Costa, Head of Chassis design, the car arriving in Melbourne in March will feature an all-new aero package.
The current F2007 does however feature all new suspension to get the best out of the new control Bridgestone rubber, as well as a new quick shift seven-speed gearbox.
On the engine side, the F2007 features the same 056 powerplant as last year as per the rules package but has been modified to allow for the reduction to 19,000 rpm demanded in 2007.
Kimi Raikkonen, Michael Schumacher and Luca Montezemolo were all on hand for the first laps in the F2007.
http://www.f1-live.c...115131016.shtml
Here is another photo with less fog
