Air Flow Disruption
30 replies to this topic
#1 james
james
  • 287 posts
Posted 27 March 2007 - 07:19 PM
I thought of this last night while trying to sleep and after a little refining it seems that it could work quite well. Basically the idea is to use the engine to power an air compressor that can fill up  one or more air tanks in various positions around the car. I read somewhere that most cars carry between 50-70 kg of ballast, so the weights of the tanks themselves could be taken out of the ballast. Next you run lines to the bottom of the car that point forward. When the car hits a straight the driver simply hits a button to releast the air. If done right it could probably halt the flow of air under the car almost completely, taking away loads of downforce. And if you didn't want to use tanks you could probably hook up a clutch to the air compressor so it engages when the driver tells it to and pumps out air in proportion to how fast the car is moving. Another thought would be to make the nozzles on the diffuser adjustable so that during braking and cornering they are pointing to the rear to speed up the airflow and increase downforce, then change back when going down a straight.
If the FIA tried to outlaw the system you could argue that its just movable ballast even though the weight of the air itself, if I've done my calculations correctly, shouldn't be more than 5 kg. As shown below compressed air is fully within the rules.
Technical Regulations
ARTICLE 4: WEIGHT
4.1 Minimum weight:
The weight of the car must not be less than 605 kg at all times during the Event.
4.2 Ballast:
Ballast can be used provided it is secured in such a way that tools are required for its removal. It must be possible to fix seals if deemed necessary by the FIA technical delegate.
4.3 Adding during the race:
With the exception of fuel and compressed gases, no substance may be added to the car during the race. If it becomes necessary to replace any part of the car during the race, the new part must not weigh any more than the original
I'd like to hear what you think. Good or Bad. Hold nothing back.
" I never think I can hurt myself, not seriously. If you believe it can happen to you, how can you do this job? If your never over eight-tenths, or whatever, because your thinking about a shunt, your not going as quick as you can. And if your not doing that, your not a racing driver. Some guys in Formula 1... well, to me, they're not racing drivers. They drive racing cars, that's all. They're doing half a job. And in that case, I wonder why they do it at all..."
"To give anything less than your best is to sacrifice the Gift."
#2 Shane2
Shane2
    Victory shall be mine!
  • 2,790 posts
  • Interests:If you really want to know PM me
Posted 27 March 2007 - 07:22 PM
In theory, possible but I doubt a device like that would quantify as ballast, and I don't think it would be likely to pass a scruitineering check
Beta-Place | Pixita Image Hosting
An official, and proud member of the Ferrari Hating "Biased Jerk" Society
#3 spitfire
spitfire
  • 247 posts
Posted 27 March 2007 - 07:32 PM
ARTICLE 4: WEIGHT
4.1 Minimum weight:
4.2 Ballast:
Totally interesting idea hard to imagine it getting used ...but then again who knows. i wonder how much force would be required to move the air back out front of the aero? How much tanks capable of holding compressed air would add to the overall weight? how much would the movement of air destabilize the car?
how is this (Ballast can be used provided it is secured in such a way that tools are required for its removal) part of the rule interpereted?
all interesting questions???
#4 rumblestrip
rumblestrip
  • 514 posts
Posted 27 March 2007 - 09:21 PM
Kind of reminds me of the old Brabham fan car.
#5 Autumnpuma
    Back in black
  • 8,830 posts
Posted 27 March 2007 - 10:45 PM
Your argument about moveable ballast would not work. All ballast must be secured and non-moveable.
Wouldn't the release of air need to be done at a velocity greater than the incoming air in order to negate it's flow under the car? That would require one helluva forced-air system that would need to consistantly, over the duration of any given straight, blow at a speed greater to the windspeed hitting the car. Also it would possibly add considerable weight to the car. You could use that weight as ballast, but ballast is moved around the car depending on the circuit and this system would be locked into place at one spot on the car.
Your idea about the back of the car seems more do-able, but one could argue that the moveable nozzles are moving aero devices as they serve no function except to affect the aero of the car.
Interesting ideas, but I think it's a moot point. Ferrari are pushing the envelope and will eventually get a ruling against them. All innovation is going by the wayside, but I applaud your innovative spirit!! Long live Colin Chapman!!
Don't rest in peace, Bruce. Raise Hell.
______
Give me a roof over my head, some food to eat and a fast car. That's all I need.
That's all I'll ever need.
----Robert Kubica
"Gilles was the last great driver. The rest of us are just a bunch of good professionals."
----Alain Prost
The only true sports are motor racing and mountain climbing; everything else is just a game.
TF1 Blogs: be afraid, be very, very afraid..........
#6 james
james
  • 287 posts
Posted 28 March 2007 - 02:39 AM
I've had a little more time to think about it and the ballast idea wouldn't work. Too many rules. However, I'm pretty sure the airflow out of the nozzles wouldn't need to be greater than the airflow coming in. If that happened it would come close to eliminating all the airflow and you'd lose most if not all of your downforce, I think. It would be like riding on a mound of air. Whatever difference they could make in airspeed and pressure should do the trick. I should have developed the idea a little more before I posted. Oh well, no harm done. It was this kind of thing that first got me interested in Formula 1 and it upsets me to think of the way the sport is going.
#7 Autumnpuma
    Back in black
  • 8,830 posts
Posted 28 March 2007 - 04:59 AM
Ahhh, I get you. I was assuming you wanted to eliminate most, if not all, the airflow from under the car. Reasonable because you really wouldn't need it on the straights anyway; the rear wing would be enough to keep proper traction of the rear tyres....
On your last statement, yes I agree. F1 is too technical in some ways (driver's aids) and too restrictive in others (flexible wings, TMDs).
______
----Robert Kubica
----Alain Prost
#8 Max Mosley
Max Mosley
    Cleaning up since 2004
  • 8,810 posts
Posted 04 April 2007 - 10:57 AM
I still don't know why we want to reduce downforce on the straights.  Rolling resistance?  I'd like to know how much of a difference it would make.  Normally it's very small, but F1 could be very different of course.
To be a willing slave of a loving God's commands,
That's the key to a freedom that I'll never understand.
--Shad K., biggest thing out of Canada since Pamela's double Ds.
Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream.
--Mark Twain (1835-1910)
#9 rumblestrip
rumblestrip
  • 514 posts
Posted 04 April 2007 - 12:37 PM
I think the line of thinking is that downforce = drag, or something.
#10 james
james
  • 287 posts
Posted 04 April 2007 - 01:09 PM
When a F1 car is at full speed its generating something like 2.5 times its weight in downforce. With that much weight you need more power to keep it moving or to accelerate it. An example would be to take a car and take it out to the track and top it out. Now take the same car and load it down with twice its weight in lead. Your going to have a hell of a time getting it up to the same speed. If F1 hadn't outlawed movable aero and ground effects we would more that likely be seeing 250 to 300 mph (400 to 480kph) speeds down the straight, if not more. Thats my understanding of it. Correct me if I'm wrong.
#11 Shane2
Shane2
  • 2,790 posts
Posted 04 April 2007 - 04:57 PM
Its more than that, at full speed it generates 2,500 kilos of downforce.
#12 Autumnpuma
    Back in black
  • 8,830 posts
Posted 04 April 2007 - 11:12 PM
The only use for downforce is to corner faster. On the straights you only need enough downforce to keep the tyres in contact with the tarmac. Too much downforce would be akin to this:
In autosports, downforce=low pressure under an airfoil. Drag=low pressure behind a surface facing into the wind. In physics, the definition is 'aerodynamic drag'  and is very generic: the resistance caused by a gas to the motion of a solid body moving through it. In autosports, drag describes that resistance as the low pressure behind, say, a tyre, pulling the tyre backwards much like a vacuum. Drag can also be the air hitting the front of that tyre and slowing it down, but that is further refined when talking about an airfoil; in the case of an airfoil, that 'drag' is called deflection and is a part of the downforce equation, not the drag equation. Is anyone confused yet? I am...
______
----Robert Kubica
----Alain Prost
#13 james
james
  • 287 posts
Posted 04 April 2007 - 11:17 PM
Well said.
#14 Max Mosley
Max Mosley
  • 8,810 posts
Posted 06 April 2007 - 06:22 PM
Yeah, that seems to be the kind of idea.
Weight only affects speed via Newton's second law, F=ma.  So if your car weighs more, then a given engine will produce lower acceleration.  This won't affect your top speed though - it will just take longer to get there, as your acceleration is reduced.  Also, note that downforce is not like weight in this context because it doesn't have inertia (its effect on the car's mass is zero) and therefore doesn't appear in F=ma and won't slow the car down.
If you're interested, there are two types of mass: gravitational mass and inertial mass.  The first describes how strongly affected by gravity a body is (the gravitational force being proportional to the gravitational mass of the body), and it is exactly analogous to electric charge, which tells us how strongly affected by an electric field an object will be.  The latter is totally different.  It tells us a body's resistance to being accelerated - if you like, it tells us how hard the object is to push.  It is the inertial mass which appears in F=ma.  The fact that gravitational mass is always identical in value to the inertial mass is an amazing thing and was one of Einstein's main clues when he invented General Relativity.  (The equality of the two values means that being in a gravitational field is exactly the same as being accelerated in a vertical lift or F1 car!  In both cases you get pushed down into the ground.)
Adding weight to the car increases both types of mass (as they are always equal) - meaning that the car is harder to accelerate (inertia is greater) but also that it pushes against the ground more, but those two effects are totally separate.  Adding downforce doesn't add mass (of any sort as they're always equal) so there is no change to how hard the car will be to accelerate (inertia unchanged) but it will push harder into the ground.
Yeah I agree.  You don't need very much downforce on a straight (just enough to apply the engine's max power), but I don't think it will slow you down much, unless via rolling resistance.
Yeah that's right and I think the two definitions are pretty much equivalent. ;)
Edit: of course reducing drag would speed you up on a straight and reducing downforce normally reduces drag.  But they are not always proportional to one another and I just want to get the distinction clear on the forum, at least for the more technically-minded folks!
Edited by Murray Walker, 06 April 2007 - 06:32 PM.
#15 james
james
  • 287 posts
Posted 06 April 2007 - 06:48 PM
There is a price for this amount of downforce. Drag. Redirecting the energy of the airflow to hold a car down creates more resistance for the car to push against. But that's OK. Although drag reduces top speed somewhat, the increase in cornering speeds makes for faster lap times, so some drag is acceptable. Many race cars have drag coefficients of over 1.1, while modern production cars hover around 0.35. The big difference is that race cars have enough horsepower to compensate.
The key is to produce just enough downforce to maximize the average speed around the track. Produce too much downforce and the increased drag will slow the car excessively, too little downforce will hurt cornering speeds. It usually takes some experimenting with wing settings and other components to find the sweet spot where performance is optimized.
http://www.sportcomp...dynamics_part_2
This sounds about right. I was wrong in assimilating the downforce to added mass. But as it says, adding more downforce increases the amount of drag, which would make the car harder to accelerate.
So basically in order to change the direction of the air requires energy in the form of drag. To lessen the drag you either need to have very little downforce or a very efficient aero package.
Edited by james, 06 April 2007 - 08:12 PM.
#16 Max Mosley
Max Mosley
  • 8,810 posts
Posted 08 April 2007 - 01:49 PM
Yeah that sounds about right! :)  I just wanted to get the distinction clear between drag and downforce really.  They are not proportional to each other in general, so we shouldn't use the terms interchangeably.  Reducing drag would definitely help on the straights like you say.
#17 Schumikonen
Schumikonen
  • 4,280 posts
Posted 25 April 2007 - 09:08 AM
FIA steps up illegal floor offensive
Changes ahead of the Spanish Grand Prix
F1's governing body has stepped up its offensive against illegal floor bodywork, according to reports.
The specialist publication Auto Motor und Sport said the FIA's Charlie Whiting has now informed all teams that tests to ensure the rigidity of cars' underbodies will be even stricter at the Spanish Grand Prix next month.
The saga first hit the headlines after the Australian Grand Prix, when teams including Ferrari and BMW Sauber were accused of deliberately circumventing the rules to obtain a performance advantage.
The FIA's subsequent clarification affected the design of most Formula One teams' floors, sources said.
But Auto Motor und Sport contends that Ferrari and BMW's original floor designs passed even the stricter test; motivating the FIA to now quadruple the amount of load applied for the new Barcelona tests.
Toyota's Pascal Vasselon suggests that the move may force some teams to totally re-think their underbody setups, because too stiff a floor is likely to break over the kerbs.
"Many teams will have to raise their cars quite a lot," he said, "but (raising a car by) only a millimetre can mean two per cent less downforce."
Source GMM
CAPSIS International
http://www.totalf1.c...p?newsid=203363
What will happend now?
Kimi Raikkonen: It is the same thing that I said before. I have no interest in driving for a bad team next year. If I race here, I always try to finish as high as I can. I don't need anything to motivate me. If I drive, I drive to do my best and that is it.
jemstride:
"I get the feeling that Alonso fans tend to heap over-praise on Alonso and bring down Kimi whenever they can, with mere theories and unjustified statements."
I just always end up disagreeing with you guys because of all the huge exaggerations, myths, theories & unjustified statements
Lewis Hamilton:
I never go with expectations, I go with a target. That is to be at the front, and the ultimate aim to win, which is the mentality I have always gone racing with.
You've got to be on the limit all the time - and I love that, because that's how I love to race.
#18 scarbs
scarbs
    Test Driver
  • Junior Members
  • 9 posts
Posted 25 April 2007 - 03:00 PM
I doubt the compressed air idea would work as described.  Besides any sort of active aerodynamics like this are strictly outlawed.
Bleeding pressurised air over aero surfaces is a well known practice, Aircraft often blow air through slots on large wings\flaps to prevent the device stalling.  In some respects the use of the exhausts blowing under the rear wing are a similar solution (or through the diffuser if you go back to the eighties\nineties)
Drag and downforce are linked, downforce squares with speed, while drag cubes.
Thus at higher speed drag increases to the point where to add any top speed would require huge increases in HP.  If you can reduce drag you can get a higher top speed, but as we've already seen we still need downforce to get around corners.  At high speed downforce is doing nothing for the car, thus if you can reduce downforce, then you also reduce drag, which will improve top speed.  This is why every team use clever flexible wings that flatten off at high speed, thus they give downforce in the corners (slower compared to the straights), but give lower drag on the straights for high top speed.
#19 monza gorilla
monza gorilla
    Forum artefact
  • 6,649 posts
  • Interests:Adnams Broadside. Fullers ESB.
Posted 25 April 2007 - 03:19 PM
A novel idea. Somewhere in the back of my mind I recall that this compressed air idea, or a variation thereof, has been used on powerboats, to separate the hull from the water. I must think on this some more.
Reading: other peoples posts
Listening to: Cracker - Kerosene Hat
Dig that jive, Jack. Put it in your pocket, and don't look back.
#20 Max Mosley
Max Mosley
  • 8,810 posts
Posted 25 April 2007 - 05:02 PM
Yeah, but that doesn't matter much on the straights.
Interesting post.  But I've never heard this before.  Are you sure?  Normally people say that they both vary as speed squared (when measured in units of force, as opposed to power).  This is itself a huge simplification, because the drag coefficient (the "constant" of proportionality in these relationships) actually varies with speed too!  You might like to read this physics world article on the aerodynamics of football - it shows an example of the drag coefficient varying with speed.
#21 Shane2
Shane2
  • 2,790 posts
Posted 25 April 2007 - 09:22 PM
Well I hope this time that it works as desired, and anyone using illegall flexing floors get caught out
#22 Quiet One
Quiet One
    The balding avenger
  • 10,586 posts
Posted 25 April 2007 - 09:26 PM
Except Renault :whistling:
"There is more stupidity than hydrogen in the Universe, and it has a longer shelf life" - Frank Zappa
"Great drivers are the ones who win the races they're not supposed to" - K.Chandhok
"On the rare occasions that I play a racing game I often think ‘you know what this needs? A boss battle or two.’ A Formula One game in which, suddenly, everybody else has a monster truck and their sole desire is to squash you. A street racing game with a tank or two blowing the roads and buildings to bits. A Nascar game with a track that occasionally bends to the right" (Adam Smith - RPS)
#23 Shane2
Shane2
  • 2,790 posts
Posted 25 April 2007 - 09:42 PM
Including Renault. Rule Breaking = bad whoever does it (including McLaren) :P
#24 Autumnpuma
    Back in black
  • 8,830 posts
Posted 25 April 2007 - 10:13 PM
I liked the article. One thing should be pointed out, I think: the drag coefficient of a football varies only when the air is made turbulent from increased velocity, right? F1 cars, unlike footballs, are designed to smooth out the turbulent air.
______
----Robert Kubica
----Alain Prost
#25 Yoda McFly
Yoda McFly
    Established Driver
  • 336 posts
  • Interests:Err ... Cars, computers, edged implements, things that go bang.
Posted 02 May 2007 - 03:37 AM
This may be an oversimplification, and I haven't read the article yet (though I will), and I will generally bow to Mike's knowledge when it comes to aero, but ... My understanding is that the goal is to maximize the increase in downforce while minimizing (key word) the increase in drag.  IIRC, drag will always increase at a rate greater than or equal to the increase in downforce.  Hence, "a new rule designed to reduce downforce by 20%" -> "The team spent millions of dollars/pounds/euros/spacebucks in the wind tunnel over the off-season, and the engineers feel that they've regained 15% of that downforce, while reducing the drag by 5%, leading to a net decrease in lap times."
I'm all for innovation, but F1 is moving more and more towards irrelevancy (yes, I've said that before) ... Something truly innovative is only allowed if enough teams thought of it at the same time, while the rules-makers scramble to keep up.  19k rpm 2.6-litre engines?  Yeah, that's useful.  15% improvement in downforce?  That'll help my daily commute how?  Yet we keep hearing all of this "green" crap, F1 "needs to be more responsible" ... Okay, slippery slope.  This is leading into a rant for a different subject.
I'll sum up what I was trying to say with this:  BAN THE GREEBLIES!!!!111!one!
“Only an alert and knowledgeable citizenry can compel the proper meshing of the huge industrial and military machinery of Defense with our peaceful methods and goals.”
-- Pres. Dwight D. Eisenhower, 1961.  (Emphasis mine).
"I'll never understand people.  Even being one doesn't seem to help."  -- Spider Robinson, Callahan's Key
"If two men are starving and cannibalism is the only alternative to death, which man's right is 'unalienable'? And is it 'right'?" -- RAH, ST
#26 Max Mosley
Max Mosley
  • 8,810 posts
Posted 03 May 2007 - 04:29 PM
Yeah I think you're right: the drag coefficient of a football varies most when the air is made very turbulent, which perhaps happens quite suddenly, but it does change a (very) little over all speeds too.  (I think you can see this on their graphs.)  F1 cars are designed to smooth out air, as you say, but they also must do other things, like provide downforce in the corners etc.  These conflicting aims mean that in practice the air may well be quite turbulent behind an F1 car - I think this is one reason why so much downforce is lost behind another car.  Racing cars tend to have surprisingly high drag coefficients, which is what makes me think their slipstream may be quite turbulent.  Higher velocity normally leads to higher turbulence for a given geometry too, I think.  But yeah, you're basically right that a football is not a very good example here!  I would like to find some decent articles about the physics of F1 but haven't managed to find anything that interesting (yet).
:lol: Yep!
#27 Yoda McFly
Yoda McFly
    Established Driver
  • 336 posts
Posted 04 May 2007 - 12:40 AM
In truth, the area intrigues me.  Most of my aero knowledge relates to aircraft and ballistics...
With sailplanes, the big deal is maximizing lift while minimizing drag ... Seems like similar, but somewhat reversed, goals, although the shapes and speeds are drastically different.
I'd agree with you on the turbulent slipstream; what graphs/plots of CFD runs I've seen seem to confirm this as well.
Here's a tangential (bordering on OT for the thread) question, then:  with the design of the new ChampCar, much attention was paid to the design of the undertray/venturis/underwing to increase its downforce contribution, thereby allowing for less contribution to be made by the wings, all with the stated goal of reducing turbulence effects on the trailing car, and hopefully allowing for more overtaking.  We're only three races into that season, and I managed to miss the latest race (Houston) entirely, but based on Vegas and Long Beach, they might be on to something.  So, on to the question, should F1 consider this instead of bizarre-looking split rear wings as a turbulence-reducer?  I can't seem to remember why F1 mandates a flat bottom, and I'm too tired and in too much pain to look it up right now.  Maybe I will later this evening, after the beer and vicodin kick in.  (Still recovering from elbow surgery.   :yikes: )  (And discussion of whether Panoz builds cars that are inherently bad for a driver's back is definitely OT for this thread. ^_^ )
Edited by Yoda McFly, 04 May 2007 - 12:41 AM.
#28 Max Mosley
Max Mosley
  • 8,810 posts
Posted 04 May 2007 - 04:16 PM
Interesting point Yoda!  I thought the reason ground effects were banned in F1 was because they are very sensitive to the height from the ground.  So if a driver goes over a bump and bounces slightly he can lose half his downforce, which could be very dangerous in a corner of course. I wonder how they overcome this in ChampCar.  Although I'm a little skeptical of some of the driving talent in ChampCar, F1 could learn a lot from the way they run the series.  Frankly imho F1 is a big joke sometimes - it's like Bernie wants to see how bad he can make it and still get us to watch.
And I hope your elbow gets better!  No tennis for a while then. :(
Edited by Murray Walker, 04 May 2007 - 04:17 PM.
#29 Autumnpuma
    Back in black
  • 8,830 posts
Posted 04 May 2007 - 09:37 PM
ChampCar limits the amount of aero-created downforce in favor of more mechanical grip. This makes the car more forgiving when it goes over a bump. More aero (as in current F1) actually enables the car go faster than the traction circle would normally allow, so the loss of any downforce is more dangerous than a ChampCar. ChampCar drivers are running closer to the limits of the traction circle by relying on mechanical grip more than aero grip.
Fencing, not tennis.
______
----Robert Kubica
----Alain Prost
#30 Yoda McFly
Yoda McFly
    Established Driver
  • 336 posts
Posted 05 May 2007 - 07:18 AM
In general, I agree ... Specifically, as it relates to the sliding skirts, Brabham's fan, etc ... From watching ChampCars (CART, IndyCars) for as long as I've been watching F1 (I'm 30-cough, and have been involved in racing since I was a kid), though, if that's what F1/FIA/FOM is concerned about, then they just need to pop a Xanax or drink a beer, and let it go.  The downforce generated by the tunnels/venturis on a ChampCar chassis (Sitting here, I can pull definitive memories back as far as '92 ...) don't really get that far out of shape with bumps, kerbs, etc ... They do generate a bunch of downforce, and the cars definitely get squirrely, but nothing more than a good open-wheel driver should be able to handle.  Nothing at all like what would happen with a true ground-effects car when something failed there ... Anyone remember the Chapparals with the wings mounted directly to the wheel hubs?
This, I believe, is the real rub of the situation.  Over the last 10-odd years, 'most everything F1 has done has been to reduce the mechanical grip of the car.  How can that possibly be good?  Bring back slicks, bring back pre-99 (98??, hell, I can't remember) wide-track .... Allow the cars to have real mechanical grip, and I'd be willing to lay serious odds that the overall downforce levels would go way down, because of the attached reduction in drag..  Suddenly, with tonnes of mechanical grip and none of that obnoxious "dirty air" to deal with, and having your nose under someone's rear wing going into  La Source would not just be "do-able", but the best way to go ...
Just my $0.02.  I might not be sober enough, though.   :lol: .  Who knows.
Thanks.  Yeah, as mIke pointed out above, it's actually due to too much fencing.  I've actually taken the last year or so off from fencing to get the elbow fixed.  Now that the surgery is finally done, I hope/intend to start working footwork again within the next week or two, and actually be able to bout inside the next month ... After over a year off, it should be interesting.   :rolleyes:
Thanks ...
Edited by Yoda McFly, 05 May 2007 - 07:28 AM.
