PS04
Chassis material-Carbon fibre and aluminium honeycomb composite monocoque
Bodywork-Carbon fibre
Suspension-,front/rear Upper/lower carbon-wrapped steel wishbones, pushrod-activated torsion springs/rockers front/rear, mechanical anti-roll bars
Dampers-Sachs (to Minardi specification)
Steering-Minardi power-assisted rack and pinion
Gearbox-Minardi sequential, six-speed, semi-automatic, longitudinally mounted, titanium casing, hydraulic activation (Magneti Marelli ecu, Minardi software)
Differential-Minardi hydraulic/programmable units
Clutch-AP Racing triple-plate carbon
Brakes Discs - Hitco/Brembo carbon
Pads - Hitco/Brembo carbon
Cooling system-Secan Minardi-designed water and oil radiators
c##Kpit instrumentation-Magneti Marelli in steering wheel
Seat belts-TRW Sabelt six-point harness
Steering wheel-Minardi design
Extinguisher system-SPA
Wheels-OZ forged magnesium (13.0 x 12.0in front/13.0 x 13.7in rear)
Tyres-Bridgestone
Fuel cell-ATL, FT5 specifications
Dimensions (PS04B)
Wheelbase 3097 mm
Front track 1480 mm
Rear track 1410 mm
Width 1800 mm
Length 4548 mm
Weight 600 kg (including driver and camera)
ENGINE (CR3L)
Engine designation-Cosworth Racing CR3L
N° of cylinders-10
N° of valves-40
Displacement-2998 cc
V-angle-(included) 72 degrees
Fuel management system-Magneti Marelli Step 10
Ignition system-Magneti Marelli
Pistons-Aluminium alloy
Engine block and heads-Aluminium
Spark plugs-Champion
Fuel supplier-Elf
Lubricant supplier-Elf
Crankshaft-Steel
Dimensions
Length 569 mm
Depth 490 mm
Height 490 mm
Weight 105 Kg
Minardi PS04 description
Started by
webber
, Mar 14 2004 01:17 AM
No replies to this topic
