fengqingxue
How potting road construction
2 posts in this topic
Product Highlights: This product has high efficiency, low energy consumption, less pollution, easy operation advantages. Integrated asphalt heating, insulation, transportation, spraying emulsified asphalt, asphalt pavement heating, recycling old material and many other features. China can complete the highway, airport runways, roads and other municipal asphalt pavement repair work quickly various diseases. The product is processed by waste asphalt mixed material recycling rate up to 90% energy efficiency heating means up to 75%.Road Repair Equipments - Road Machinery Equipment Manufacturers Technological Innovation highlights: Hydraulically controlled with a lift, sliding, rotation pavement heating means using the international advanced Blu-ray heat radiation heating technology, district heating heating area to meet the different needs pavement disease, compared with similar products with higher energy efficiency maximize the protection of the asphalt mixture asphalt composition does not age, does not burn. Insulation material box with partition infrared electrical heating technology, just 4-5 hours of cold material can be heated to 140 �� -160 ��, integrated intelligent control the Pavement Repair Equipments - Road Machinery Equipment Manufacturersheating temperature, to ensure that asphalt mixture ratio set is not destroyed, preventing the aging of asphalt . Case 1800 �� high temperature resistant interlayer of aluminum material for insulation, the maximum to prevent heat loss. Integrated machine modular design, you can add crushers, compactors and other auxiliary equipments according to the actual needs of personalization. Chassis equipped with hydraulic external interfaces, you can add a number of small hydraulic power tools. Using pressure spray old pavement renewable materials additives, and comes with more than expected and pipe cleaning hose automatic recovery feature. Antifreeze gasification gas tank insulation means to ensure the feasibility of the construction of the northern cold regions. engineering machine maintenance for sale centre lathe advantages and disadvantages use a left handed drill bit how to fix spalling concrete
There are generally two kinds of pavements which are best for road construction that is asphalt and concrete. Concrete is a hard surface material that is commonly used in driveways, but due to its light color, it stains very easily and shows every color. That's why most people select asphalt pavement because of its dark color it won’t show stains easily. There are many professional for asphalt driveway in Long Island who provides the best services of asphalt pavement which prevents a smooth, well-bonded surface free from loose particles.
