Monty 0 Report post Posted May 7, 2005 http://homepage.mac.com/emeseditorials/F1/...Theater301.html Turn up the volume Share this post Link to post Share on other sites
pumpdoc 2 Report post Posted May 7, 2005 As all SPEED tv veiwers know their F1 coverage is tops!! Share this post Link to post Share on other sites
ecapdeville 0 Report post Posted May 7, 2005 Now I understand ! Ohh BAR, you Naughty boys... Share this post Link to post Share on other sites
rebbewin 0 Report post Posted May 7, 2005 Thanks for that one. Although i had an idea that's what the problem was it' a lot clearer now! My question is this. You know it's funny how the BAR lost its pace in the last stint of most of the races last year. Imola was a great example of that. It fell right of the pace in the last stint but was fast in the middle. Share this post Link to post Share on other sites
jackgarrett 0 Report post Posted May 7, 2005 what do speed only do F1? Share this post Link to post Share on other sites
pumpdoc 2 Report post Posted May 8, 2005 what do speed only do F1? <{POST_SNAPBACK}> Speed covers just about all forms of motorsport from all over the world, go to speedtv.com and check it out Share this post Link to post Share on other sites
ecapdeville 0 Report post Posted May 8, 2005 Speed covers just about all forms of motorsport from all over the world, go to speedtv.com and check it out <{POST_SNAPBACK}> Yeah! I Share this post Link to post Share on other sites
Kay 0 Report post Posted May 8, 2005 BAR didn't cheat though - the FIA have confirmed that. BAR were overweight at all times so they had no advantage at any point, it was just the fact that they designed a system that 'could' allow them to run underweight, but then the system fails after it has under about 6kg so they can't. BAR used FIA data to prove they were never underweight and the only thing the FIA have said is they lied basically, but then so did Jo that FIA delegate in Malaysia as he saw the fuel cell in great detail and never said anything to BAR about if it was clearly within regulations or not and so BAR carried on using it as no one had questioned them once they had seen it. Share this post Link to post Share on other sites
Sato 0 Report post Posted May 8, 2005 Using fuel as ballast as illegal. Share this post Link to post Share on other sites
Fed up 0 Report post Posted May 8, 2005 Using fuel as ballast as illegal. <{POST_SNAPBACK}> Read max's autosport interview and draw your own conclusions. It is obvious that BAR have been singled out Share this post Link to post Share on other sites
Sato 0 Report post Posted May 8, 2005 Well if you don't cheat, you can't be singled out, its their own fault. Share this post Link to post Share on other sites
Fed up 0 Report post Posted May 8, 2005 Well if you don't cheat, you can't be singled out, its their own fault. <{POST_SNAPBACK}> IMO the only individuals that are claiming that BAR have cheated are Bernie and Max and perhaps your goodself. Share this post Link to post Share on other sites
Sato 0 Report post Posted May 8, 2005 Its been proven. It is illegal to use fuel as ballast, BAR don't deny having the system, which means that they did. Share this post Link to post Share on other sites
Fed up 0 Report post Posted May 8, 2005 Its been proven. It is illegal to use fuel as ballast, BAR don't deny having the system, which means that they did. <{POST_SNAPBACK}> ok Share this post Link to post Share on other sites
Shadow 0 Report post Posted May 8, 2005 Its been proven. It is illegal to use fuel as ballast, BAR don't deny having the system, which means that they did. <{POST_SNAPBACK}> agreed and i feel the punishment was quite fair too Share this post Link to post Share on other sites
bajo39 0 Report post Posted May 8, 2005 BAR didn't cheat though - the FIA have confirmed that. <{POST_SNAPBACK}> Rubbish. BAR were not found guilty of running below weight in the race but this is far short of the court confirming their innoncence. In fact, the report specifically pointed out the difference and went on to imply that BAR were probably cheating. Do not bother telling me about the obviously suspect internal BAR data as you have already damaged your credibility enough for one day. Share this post Link to post Share on other sites
Fed up 0 Report post Posted May 8, 2005 Rubbish. BAR were not found guilty of running below weight in the race but this is far short of the court confirming their innoncence. In fact, the report specifically pointed out the difference and went on to imply that BAR were probably cheating. Do not bother telling me about the obviously suspect internal BAR data as you have already damaged your credibility enough for one day. <{POST_SNAPBACK}> "Imply" Implications are subjective Share this post Link to post Share on other sites
Kay 0 Report post Posted May 8, 2005 Rubbish. BAR were not found guilty of running below weight in the race but this is far short of the court confirming their innoncence. In fact, the report specifically pointed out the difference and went on to imply that BAR were probably cheating. Do not bother telling me about the obviously suspect internal BAR data as you have already damaged your credibility enough for one day. <{POST_SNAPBACK}> They didn't find BAR guilty of fraud, wait I'll find the Nick quote again for you. Even FIA have withdrawn the majority of what they said. Share this post Link to post Share on other sites
Kay 0 Report post Posted May 8, 2005 My credibility is fine thank you. Ted Kravitz: Is it the harsh penalty you Share this post Link to post Share on other sites
Kay 0 Report post Posted May 8, 2005 WHEREAS, taking into account these requirements, the car, at all times of the event, must weigh with the driver a minimum of 600 kg and that Lucky Strike BAR Honda tried to argue that the car must be weighed with the remaining fuel in the tank after the race, which is not supported by any rules of the Code and Regulations, and leaves the FIA as well the competitors in a regrettable state of uncertaintyWHEREAS it is not possible for the Court to find, on the basis of the evidence that it was provided with, that Lucky Strike BAR Honda deliberately committed fraud, Share this post Link to post Share on other sites
Fed up 0 Report post Posted May 8, 2005 They didn't find BAR guilty of fraud, wait I'll find the Nick quote again for you. Even FIA have withdrawn the majority of what they said. <{POST_SNAPBACK}> My point exactly.. But try convincing bajo39 Share this post Link to post Share on other sites
Kay 0 Report post Posted May 9, 2005 ....Is a completely different ball game Share this post Link to post Share on other sites
nojvnof1 0 Report post Posted May 10, 2005 weren't BAR guilty of lying to the stewards? The FIA knew all about this system, but when a steward asked if the tank had been COMPLETELY drained, one of the BAR crew present said yes, when in fact there was still an amount of fuel in the special catchment. Share this post Link to post Share on other sites
Kay 0 Report post Posted May 10, 2005 No they did not ask if it was completely drained. When using a pump, they asked 'Is that it?' Nick Fry, who did not know the technical runnings of the fuel system replied 'yes', as that was all the fuel that could be drained using that pump. That is why the court and FIA said 'lack of transparency', because they pushed the truth a bit too far and I am sure someone was there such as GW who could turn around and say no. So they did not blatently lie and Fry was apparently not aware that it wasn't all, however then what was he doing answering a question when he didn't know 100% the answer? That is what BAR did wrong to be called liars, but being thrown out for this saga? Just out right stupid. Share this post Link to post Share on other sites
nojvnof1 0 Report post Posted May 11, 2005 oh ok, thanks for clearing that up. Share this post Link to post Share on other sites
